I've been looking around for a tiny case that can fit a Micro ATX motherboard, and a 165mm PSU. I'm wanting to build a little APU lan rig with some spare parts, and small form factor is the goal. Thanks for any input!
p.s. I already have the mobo and PSu which is why this is so specific.
Only victors are allowed to live... this world is merciless like that.
https://linustechtips.com/topic/190840-best-micro-atx-htpc-case/
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345035&cm_re=bitfenix-_-11-345-035-_-Product
This is all i can really think of, to be honest. mATX is a bit of a wierd size for HTPC's
Edit: Fractal design node also works
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/190840-best-micro-atx-htpc-case/#findComment-2575516
I feel like the Phenom is literally just the Prodigy with a different shell. But thanks for the post. Looks like cube cases are the only way. *sigh* :P
https://linustechtips.com/topic/190840-best-micro-atx-htpc-case/#findComment-2575520
Yea, most HTPC cases are made for mini-itx
IMO the two i listed would probably look better on a  shelf than a typical htpc anyway
https://linustechtips.com/topic/190840-best-micro-atx-htpc-case/#findComment-2575536
Ya this is not actually going to be an HTPC, I just want a small case really. Something I can transport easily.
https://linustechtips.com/topic/190840-best-micro-atx-htpc-case/#findComment-2575612
