Hey guys, so i had a computer and i was using it, then i had to stop during 2 weeks, now i went to connect the cables and stuff and when i turn on everything, the monitor says "HDMI power saving mode", i have been waiting for my new pc, today i got it, i connected the cables, the monitor is the same, and when i turn everything on it appears the same message, the hdmi cable was on the mobo so i decided to try it on the graphics card, it turned on well but then i turned everything off and on again and it doesn't work again, says the same thing.
Could it be the monitor ?? the monitor cables ??
Thanks in advance.
https://linustechtips.com/topic/190692-power-saving-mode-issue/
my screen does that sometimes when i disable crossfire... when you turn the pc on do you see the bios screen if no try plug something else in to the monitor see if it comes on then if no then try DVI or VGA
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/190692-power-saving-mode-issue/#findComment-2572757
only thing that i see is the lg logo then it says that and goes black...
https://linustechtips.com/topic/190692-power-saving-mode-issue/#findComment-2572781
1. Is your monitor working with other devices (e.g. console, tv, other pc, laptop)?
2. Did it work with onboard GPU?
3. Reset your monitor settings.
1.as i said, i've tried 2 computers and none worked
2.it didn't and when i tried on the evga it worked first time but when i turned off and on again it didn't work and said the same thing
3.what do you mean ??
https://linustechtips.com/topic/190692-power-saving-mode-issue/#findComment-2573100
