I started up my PC like usual and noticed that i can't play tf2. I went ahead and restarted the pc to see if that'd fix it and now i get all sorts of errors and i can't connect to the internet AT ALL (from my pc). I am running a spyware terminator scan and a bitdefender total security system scan. I'll post some error pics soon. In the network settings it says i am connected to the internet.
Edit: one of the more common start up errors i am getting is "WSAStartup() error:"
Samung Tab S 8.4
https://linustechtips.com/topic/190187-help-programs-and-internet-screwed/
I'm assuming windows. In which case, more likely than not a corrupted system file or registers entry.
Boot off of your install disk am dun the repair utility.
It that doesn't work, try:
superuser.com/questions/633550/wsastartup-failed-or-you-have-the-incorrect-version-of-winsock-installed
