Gentle Typhoon Replacement?
Go to solution Solved by helping,
NOCTUAAAAAAAAAAAAAAAAAA!
Please let the door hit you on the way out
@Lays is selling 8 of them on the classifieds and they have only been used a few months. I think you can find them in stock in some places as well. I use the Swiftech Helix which are basically identical, they perform the same and look better in my opinion.
too late, nanners already buying them
OP if you want you can probably buy them from nanners in about a week or two.
NB e-Loops if your down with white and black but they're not as good as gentle typhoons.
eloops are extremely good, I'd say they're about equal with GT's sharing absolute top shelf.
this is telling and may help you decide.
http://www.xtremesystems.org/forums/showthread.php?286088-Fan-Testing-Round-12-NB-e-loops-Cougars-Noctua-Piranha-GT-AP-45s
I want to do a new water cooling loop and would normally get gentle typhoon ap15's, but now with scythe discontinuing them, individuals want stupid amounts for a single fan.
I went looking for reviews and found "ronsanut", had done various fan comparisons on a rad.
The Akasa Apache black score fairly well and is low rpm. Any one had experiences with this fan?
If only we all could afford 8 SSD's in Raid 0  :wub:
https://linustechtips.com/topic/189728-gentle-typhoon-replacement/
Noctua P12?
"Rawr XD"
SP120s quiet editions
He already sold them +1 for swiftech helix
Noctuas are loud compared to other fans
Error: 410
Noctua wasn't going to be an option for me, I dislike the colour scheme, so I'd have to buy the industrial ones (Black with brown anti-vibration inserts) with a 5v/7v reduction cable, but that would cost me £25 a fan.
Cheers I'll look into the NoiseBlocker Eloops then. £15 a fan is much easier to swallow. Cheers everyone.
