Hello !
i want to buy some new parts for my PC
My Pc:
FX-6100
Gtx 760 Zotac
Asus Crosshair v
8 gb ram
630w Psu
I want to buy a second gtx 760 (but i dont know which one) and a new CPU ( FX- 8350 | my old cpu is on 4.1 ghz) So do you think i can oc and run the system stable?
https://linustechtips.com/topic/189184-need-help-for-my-pc/
1) Yes, you can overclock.
2) Yes, it will run stable, unless something disastrous happens during the building process.
ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
It feels as though no games ever leave the BETA stage anymore, until about 3 years after it officially releases. - Shd0w2 2014
https://linustechtips.com/topic/189184-need-help-for-my-pc/#findComment-2555829
If your going to buy a second 760 I would be careful;
Your power supply is only 630w, if I was going to use any sort of 2-Way configuration I would at bare minimum get a 750w PSU that is a well known brand and continues power.
If I was you I would think about getting a R9 280x or a GTX 780. Then maybe upgrade your CPU to a 8350. Also I would get an SSD.
https://linustechtips.com/topic/189184-need-help-for-my-pc/#findComment-2556943
@Bagmup Dark Rock advanced
@BradBoiii Yeah i will buy a 850 w i think because it is future oriented but i think i will stay on my 760 because i think the price performance ratio is a little bit better and because i am a student i cant buy a 780 i mean the cost of a gpu and psu are nearly at the price of one 780... btw i have a ssd
https://linustechtips.com/topic/189184-need-help-for-my-pc/#findComment-2573413
