Get a different SSD, that one is crap.
Try to get 8 GB of RAM.
I would get a Barracuda instead of a Green, it'll be a bit faster.
Get your Windows key from G2A, it will save you a lot of money.
I would get a more... classy looking case, that one is kind of... 'gamer' oriented.
Besides that, looks good.
https://linustechtips.com/topic/188564-600-dollar-home-pc-build/#findComment-2538966
Could be cheaper
CPU: AMD A10-6790K 4.0GHz Quad-Core Processor  ($129.97 @ OutletPC)
Motherboard: Gigabyte GA-F2A55M-S1 Micro ATX FM2+ Motherboard  ($34.69 @ Newegg)
Case: Cooler Master Elite 430 ATX Mid Tower Case  ($27.99 @ Newegg)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($25.98 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $461.99
Generated by PCPartPicker 2014-07-29 14:49 EDT-0400
https://linustechtips.com/topic/188564-600-dollar-home-pc-build/#findComment-2539019
I am building a Home PC for my aunt and I wanted to see if these parts are good.
http://pcpartpicker.com/p/766923
Give any advice or changes that you think would make it better.
I would much rather get an APU then an i5
An SSD for older people does wonders, it makes the PC feel so fast :)
And do you really need a modular PSU for that build?
"Rawr XD"
https://linustechtips.com/topic/188564-600-dollar-home-pc-build/#findComment-2539029
If he's getting an SSD then might as well stick with the green. Less heat, ,less noise, less vibration, less power, longer life
G2A is getting more and more hit and miss
"Rawr XD"
https://linustechtips.com/topic/188564-600-dollar-home-pc-build/#findComment-2539034
I would still prefer a Barracuda personally, just in case it will be re-purposed for something else someday or just to make general things faster like if they ever want to install games/programs to it. I've never used G2A so you may be right, I'll have to look into that, thanks.
https://linustechtips.com/topic/188564-600-dollar-home-pc-build/#findComment-2539070
But you want your drive to last to that "someday" right? :P
"Rawr XD"
https://linustechtips.com/topic/188564-600-dollar-home-pc-build/#findComment-2539083
A couple of suggestions. 2x4GB of memory, the part in the below list had the best pricing. I did not choose it for the speed. A Seagate Barracuda, if you prefer a WD Blue is about the same price. (I have to admit to not liking WD Greens after a number of problems.) A less expensive case and psu. Still good quality. The case is an mATX case.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($179.99 @ Newegg)
Motherboard: MSI H81M-E35 Micro ATX LGA1150 Motherboard  ($61.51 @ Mwave)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1866 Memory  ($72.99 @ Amazon)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($50.40 @ Amazon)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply: Antec Basiq 350W ATX Power Supply  ($29.98 @ OutletPC)
Optical Drive: LG GH24NSB0 DVD/CD Writer  ($13.99 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($93.95 @ B&H)
Total: $597.79
Generated by PCPartPicker 2014-07-29 20:20 EDT-0400
https://linustechtips.com/topic/188564-600-dollar-home-pc-build/#findComment-2541751
