Help with Javascript
Solved by fizzlesticks,
You're changing the height of the box but you're comparing the width of the box. Change curr_width to curr_height and read back the height instead.
edit: Also "=" is used to set a variable, you need to use == or === to compare values.
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
