This has NEVER happened to me before and to be quite honest it is pissing me right off.  All keyboard controls would not work at all and I was troubleshooting it for almost an hour.  (Yes I did change the bGamepadEnable=1 Setting to zero, not sure why that was enabled as an xbox controller has never even touched my PC) Now for some reason I have to activate the steam overlay (shift + Tab) for keyboard controls to work.  If I dont do that then there is no way for me to play the game whatsoever.  Are there any suggestions?
https://linustechtips.com/topic/188155-skyrim-bug-possible-fix/
Try deleting your skyrimprefs.ini and skyrim.ini in the
my games folder and then open skyrim up.
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/188155-skyrim-bug-possible-fix/#findComment-2533094
now skyrim opens in a really tiny window  :(  :(
Did you set the settings back to what you want in the skyrim launcher?
Restarting Skyrim shouldv'e added a fresh Skyrim.ini and Skyrimprefs.ini
Try to download them from here http://forums.steampowered.com/forums/showpost.php?s=f36e617ef710fd3d0965a8dcdc612388&p=26470720&postcount=3
and then put them where you deleted the two inis from
https://linustechtips.com/topic/188155-skyrim-bug-possible-fix/#findComment-2533175
