I need help with a python exercise
Go to solution Solved by fizzlesticks,
You need to find the minimum weight limit for the 3 bridges. Python has a function called min() that can do it for you. Pass all of the weight limits to that function and it will return whichever is the smallest.
1474412270.2748842
