I just bought an Asus ROG Xonar Phoebus and have the optical out (TOS link) from the new card to my Earforce DSS. I can't get the DSS to work on the Dolby Digital setting though, it's stuck on ProLogic - consequently I don't have pseduo 5.1 in my headphones as I did with the X-Fi Fatality.
What am I doing wrong?
https://linustechtips.com/topic/18466-xonar-phoebus-and-earforce-dss/
Trying to use pseudo 5.1. :P
Sorry, sorry, I'm not ACTUALLY trying to troll, I just can't stand those "effects". Is it something you really can't live without? I would suggest trying it for a while, you may find you like it.
Desktop - Custom watercooled R4E/i7 3930k/GTX 780 SLI/32gb 2400mhz DDR3/Xonar STX/OCZ V4 256gb RAID 0/24tb RAID 5
Laptop - Clevo P370EM - i7 3630QM/GTX 680M SLI/8gb 1866mhz DDR3/840 pro 256gb RAID 0/750gb mechanical
I prefer headphones when gaming and I can't afford an expensive 5.1 headset. The DSS does a great job of 3D surround sound in 2 channel headphones.
I managed to sort it, I had to go into Control Panel--Sound--Playback--Digital Audio (S/PDIF) click properties--Advanced and change default format to Dolby Digital Live...if anyone's interested.
