I was hoping to build my first PC with a budget of anywhere around £800-£1200.
This is what I have picked out, I will be getting an OS at a later date. At first I will not be OCing but I may consider when feeling confident about it. Any suggestions are welcome and would be appreciated, Thanks!
http://uk.pcpartpicker.com/p/hCHnyc
https://linustechtips.com/topic/184242-first-build/
@Zaaraus
How is this. It is an Orange/Black themed build at the same price point as the build you linked. You could switch out the I5 for an I7 if you are doing frequent editing.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£166.98 @ Scan.co.uk)
CPU Cooler: Phanteks PH-TC14PE_OR 78.1 CFM CPU Cooler  (£64.97 @ Scan.co.uk)
Motherboard: Gigabyte GA-Z97X-SOC ATX LGA1150 Motherboard  (£139.32 @ Scan.co.uk)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  (£65.14 @ Amazon UK)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card  (£295.55 @ Scan.co.uk)
Case: Corsair Air 540 ATX Desktop Case  (£98.95 @ Amazon UK)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£80.90 @ Amazon UK)
Total: £1055.18
https://linustechtips.com/topic/184242-first-build/#findComment-2475728
At the lower end of your budget. An i5 is more than enough for gaming and general desktop use. The 4690K on a Z97 ROG motherboard has to option to overclock when and if you decide to try it out. A very nice but less expensive tower case to house everything. And a better sized power supply.
You might consider upgrading from a GTX 770 to a GTX 780 or R9 290.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.25 @ Scan.co.uk)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard  (£158.36 @ Scan.co.uk)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  (£61.74 @ Ebuyer)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  (£57.19 @ Aria PC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£36.00 @ Aria PC)
Video Card: MSI GeForce GTX 770 4GB TWIN FROZR Video Card  (£273.32 @ Scan.co.uk)
Case: Phanteks PH-ES614PC_BK ATX Full Tower Case  (£77.53 @ Scan.co.uk)
Power Supply: XFX XTR 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£84.78 @ Scan.co.uk)
Total: £940.15
Edit: changed to a more compatible memory kit.
Memory: Kingston Black Series 8GB (2 x 4GB) DDR3-1600 Memory  (£58.18 @ Amazon UK)
Total: £936.59
https://linustechtips.com/topic/184242-first-build/#findComment-2475968
