Hi guys,
As the title explains it all i need help with a good gaming/web designing.
For the games i want to be able to play Far Cry 3 without lag.
I also want to get Water cooling and not a CPU cooler.
This is what I think would be good if you can think of a better item i would be glad to hear it.
Also Budget: $2500
Case: Cool-master CM Storm Scout 2 Black
CPU: Intel Core I7 3820
GPU: (Was thinking graphics card's already mounted with water blocks x2)
Memory: 16GB (not sure what brand and what i look for so i can mount the liquid cooling stuff)
Power Supply: Cooler-Master Silent Pro Gold 1200W
Liquid cooling: ( not sure what one to get)
Optical drives: LG BH16NS40 16x BD-R Blue-ray Writer ORM
Mother Board: ASUS Sabertooth Z77
So again Budget: $2500 the cheaper the better Sorry about this i'm not sure what type of stuff I should build with.
So Far in total it is $1004
Edited by Wally
https://linustechtips.com/topic/18398-need-help-with-computer-build/
To be honest it think you would be better off either getting a 3770k or wait for haswell.
The extra threads of the 3770k would help in photoshop ect. And any high end Z77 Asus board is good.
Also are you planning on doing a custom water cooling loop if so have you done it before ?
yes i am thinking of doing a custom water cooling loop and yes i have done it before.
Okay thats alright then i was not sure if you have ever done one before.
I would just suggest you wait till haswell is out which i think is soon. No point getting hardware that is going to be out of date like next month.
Also ram brands i would recommend kingston and corsair as they are the brands i have used and never had a problem with them.
And im not to sure about GPU with blocks already mounted there are only a few i know of that have that.
