Well once you activate volume controls with the volume rocker you can also slide it using the touch screen but besides that there isn't much else you can do unless you root your phone.
sliding it with the touch screen only moves it up or down by the exact same amount as if i had pressed the volume button
Have you tried turning it off and on again?
https://linustechtips.com/topic/18250-android-volume-levels/#findComment-212484
That's as much control as you get without rooting unfortunately.
Here is one such example for rooted Samsung phones https://play.google.com/store/apps/details?id=org.projectvoodoo.controlapp&hl=en
Here's a newer one for the latest phones https://play.google.com/store/apps/details?id=com.teamkang.fauxsound&hl=en
https://linustechtips.com/topic/18250-android-volume-levels/#findComment-212899
