Power Supply for 290X Vapor-X?
Go to solution Solved by Askew,
Yeah your PSU is enough.
Hey guys,
I have a Thermaltake ToughPower XT 775W ( http://www.thermaltake.com/products-model.aspx?id=c_00001571 ) and after getting some advice from you guys between a 780 Ti and a 290X, am acquiring a Sapphire 290X Vapor-X for my 34UM95.
Will that power supply be enough for the 290X n' my rig?
AMD FX 8320
Hyper 212 EVO CPU Cooler
ASUS 990FX Sabertooth Gen3 R2.0
2x8GB Crucial Ballistix DDR3 1333 MHz
120GB SanDisk SDSSDP128G
480GB Hitachi HDS721050CLA362
72GB Western Digital WDC WD740ADFD
That's my rig in general, along with four 200mm fans and four 120mm fans (including CPU cooler).
Think the Thermaltake can power my rig?
