This is my first major build in a long time. Looking for tips, things to look out for and to keep in mind. I have two different builds I'm debating on which to do. Constructive feed back is greatly appriecated
Intel Core i7-4790K 4.0GHz Quad-Core
Asus MAXIMUS VII HERO ATX LGA1150
G.Skill TridentX 16GB (2 x 8GB) DDR3-1866
OCZ Vector 150 Series 120GB 2.5" SSD X2
Western Digital Red 1TB 3.5" 5400RPM
EVGA GeForce GTX 780 6GB Superclocked ACX
X2
EVGA 1000W
Asus Xonar Phoebus
Logitech G502 Wired Optical
Asus ROG Front Base
Corsair Graphite Series 780T
Corsair Cherry MX Red K95 RGB
Custom CPU/GPU Loop
AMD FX-9590 4.7GHz 8-Core
Asus Crosshair V Formula-Z ATX AM3+
Storage OCZ Vector 150 Series 120GB 2.5" SSD X2
Asus Radeon R9 290X 4GB DirectCU II X2
Corsair 1200W ATX12V / EPS12V
Asus Xonar Phoebus
Asus ROG Front Base
Custom CPU/GPU Loop
i5-4690K, Gigabyte Z97X-SLI, GTX 960 Gaming 4G, HyperX Fury 8Gb 1600Mhz, Corsair Spec-01
https://linustechtips.com/topic/182065-first-large-build/
Intel rig no doubt. The FX 9590 is a hot, overpriced power hog which will sometimes lag behind the i7 in performance. But switch the GPUs for R9 290X DCUII cards. The 6GB VRAM on the 780s makes near to no difference.
https://linustechtips.com/topic/182065-first-large-build/#findComment-2445925
Do you plan on doing 4K? If not I dont believe the 6GB flavors x2 are necessary.
https://linustechtips.com/topic/182065-first-large-build/#findComment-2445929
Is RAM C9? I think there are some C9 1866 Mhz RAM's out there.
I've recently watched the
. And the guy there was using 760 RoG with 4GB and he mentioned that Games are starting to use more RAM due to being console ports. As he said 'Basicly Consoles don't have dedicated Video Memory. They use the whole thing. And watch dogs was using 3.5 GB of video memory So I suggest keeping the 6GB for upcoming games.
If you were going for non custom water cooling I would have suggested a smaller case that support same or higher amount of Fan Mounting space. Since you can create a higher pressurized case that way. But I think you are ok with that case. Just make sure you have enough radiator mounting space at that case.
For my personal preference I would stay away from OCZ or anything related to Toshiba. Because my experiance with their hardware was not ok.
And since you are running custom loop for both CPU and GPU don't even bother looking for which card runs less hot then other. Just look at the performance and keep in mind that Console Ports might require more VRAM or might not. But with graphical increases I think more is always better. And you won't be needing to upgrade in close future.
Another personal preference, I never liked being on the edge, I mean if a game uses only 3.5 GB next big title can use even more then that and I don't want to get cornered to reduce my graphic settings.
All your choice in the end.
Edit: What monitor you'll be using btw?
https://linustechtips.com/topic/182065-first-large-build/#findComment-2446035
Im putting this together mainly for Star Citizen, and everything I've read says it will take everything you can throw at it.
The ram is cas 8 and the monitors are going to be three way VG248QE
https://linustechtips.com/topic/182065-first-large-build/#findComment-2446141
Yea If Star Citizen is really going to be what they say it is. Then I think it's going to be like when first Crysis launched. So I suggest not dropping below 6GB of ram even if you use Mantle (AMD based cards) because of 3 monitor setup you are going to have. There is a chance of at least 2 to 3 times more texture buffering is going to be needed. Depending on how they'll issue the multi monitor gaming.
https://linustechtips.com/topic/182065-first-large-build/#findComment-2446162
It also has 4GB of memory. Companies are saying total amount of RAM on the device to trick you to think it has twice the memory. Yes Mantle might give you better frame rate if you don't cap your 4GB of memory with that 3 monitor of yours. There are lots of debate about the performance of R9 295X2 and 780Ti Sli but I don't think anyone can provide you with accurate information at this point. Because game is not out yet. And after game comes out it has to be stabilzed with patches, driver updates. So As I said it's up to you. 295X2 looks like a beast. But in the coming months, we might need more RAM or we might not. For Current games 4GB is the edge though.
https://linustechtips.com/topic/182065-first-large-build/#findComment-2446386
