PSU + boot problems
Faulty PSU or Motherboard, RMA it.
I already explained that there is nothing wrong with the PSU, I RMA'd the PSU already last week. The PSU was tested with a PSU testbench and equipment by the company I ordered it from.
Seems a bit weird to me that the motherboard is faulty. What could there be wrong with the motherboard, since it works normal with the old PSU. It just doesn't work with the new PSU.
*EDIT*
Turns out that the company didn't test it in the right way. They just measured the value's of all outputs, not if it was capable of actually booting a PC.
I send it back with the request of trading it in for a RM850. They said they had to test it first and surprise surprise, it was faulty now! But since I ordered a RM850, they sended a new version of that PSU instead of a new V850. At first I wasn't that happy with it, I thought the V850 looked way cooler. But whatever, the PSU isn't in my sight and as long as it works I'm satisfied.
So... Nothing wrong on my end, a faulty PSU it was after all. In total it cost me 2-3 weeks till all problems were solved. But everything was free, so that's an upside to the story.
TIP: if you think your new PSU is faulty and you RMA it for testing, just day to the company that you want it completely tested, not just the values of the output power. Not like I had, that would have saved me a week.
