Hey guys i my crucial mx100 512gb ssd just arrived and i was going to replace The hdd in my lenovo y50. I have downloaded acronis image full version and have a hdd enclosure to put the ssd to clone it. However when i plug it in it doesnt show up. One of the courses of the problem may be the cable im using. The cable that plugs into the enclosure is one of those note 3 cables, a regular micro usb a extra connection thing. However i lost that cable and am using a regular micro usb. Do you guys think this is the course of the problem, the ssd isnt getting enough power?. Any help will be appreciated.
https://linustechtips.com/topic/181992-hdd-to-ssd-cloning-problems/
yes it could be that reason
but SSD can run off a 5V but may need enough current to power on
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
