Do i need a fan controller for my pc  http://pcpartpicker.com/user/andrefoster/saved/HVNv6h
Or is it a waste of money and why? Can I use my BIOS for automatic fan control
I like pc to be quiet
I am looking for something to put in the back of my pc like this http://www.sidewindercomputers.com/tbalancerbigng.html
Please Help :) :) :) :) :) :)
https://linustechtips.com/topic/181914-fan-controller/
Do i need a fan controller for my pc  http://pcpartpicker....er/saved/HVNv6h
I am looking for something to put in the back of my pc like this http://www.sidewinde...ancerbigng.html
Please Help :):):):):):)
https://linustechtips.com/topic/181914-fan-controller/#findComment-2450405
You can use the Swiftech 8-Way PWM fan controler if your motherboard has a spare PWM 4-pin connector. This is great to connect all case vents to the fan controler so they all get regulated by PWM, but be sure of two things:
  • All case coolers should be PWM (and preferible the same sizes)
  • They can't be Corsair (those require a boosted PWM signal)
If the coolers arent PWM or are Corsair, just get a normal fan controler, not the $95 thing you've linked.
https://linustechtips.com/topic/181914-fan-controller/#findComment-2450769
