System troubleshooting please help
Go to solution Solved by dragoon20005,
Since you seem like you know what youre talking about can i ask a questions
Is there a difference between OEM "generic" ram with the same speed as a " gaming" ram kit
not much difference between them
only for the AMD APUs like the A10-7850K do you need the fast 2400MHz RAMs
otherwise the 1600MHz RAMS are good for all PCs
don't waste money on gaming RAMs
So i have a computer the pc specs are
Amd 965 be but not oc'ed
Amd 5850
8gb PNY olympia Ram
500w corsair psu
I think thats all you need for the question
My question is that whenever i power on my computer after a certain time (8+ hours) it never boots up. It either gets blue screened or turns on completely unstable and then blue screens. Them i have to power it down completely by turning the switch on the psu. Regular shut downs don't do anything. Its not the gfx card because I've tried out 3 different cards. Can anyone help??
https://linustechtips.com/topic/180986-system-troubleshooting-please-help/
Amd 5850
8gb PNY olympia Ram
500w corsair psu
i am looking at RAM problems
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
And RAM prices are really high right now :/. Whats the best way to trouble shoot? Thanks
if you got 2 sticks
run with just one stick and see if it boots
reseat your cooler and clean out any dust inside your PC
reapply the thermal paste
check all power connections
if you got 2 sticks
Yea one of the ram sticks was corrupt/broken is there any way to repair or should i just throw it out?
nope
just have to live with 4GB or get a new kit
