I plan on upgrading by the end of 2014. It will be slow and I just want to make sure all the parts are compatible. Now what I have questions with is with the case and the CPU Coolers.  I know the back only has room for a 120mm Fan and not a 140mm Fan so I can't put the NZXT Kraken X41 there and I want to know if the top mounts are only 2 120 mounts or is it also 2 140 mounts. And also I have a second Kraken X41 because I plan on buying a Corsair HG10 N1 when it is released later this year, and I was also wondering if the Case can fit 2 140mm Fans up front or if it's only 1 140mm or 2 120mm. I am hoping it is 2 140mm because I plan on getting another 780 to put in SLI and also water cool with another x41 but that won't be for a while. Thanks!  :)
PCPartPicker part list: http://pcpartpicker.com/p/Nt8H7P
Price breakdown by merchant: http://pcpartpicker.com/p/Nt8H7P/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ NCIX US)
CPU Cooler: NZXT Kraken X41 106.1 CFM Liquid CPU Cooler  ($105.98 @ SuperBiiz)
Motherboard: Asus GRYPHON Z97 Micro ATX LGA1150 Motherboard  ($159.99 @ NCIX US)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  (Purchased For $0.00)
Storage: OCZ Agility 3 128GB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Samsung 840 EVO 750GB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card  (Purchased For $0.00)
Case: Corsair 350D Window MicroATX Mid Tower Case  ($84.99 @ NCIX US)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($139.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  (Purchased For $0.00)
Monitor: BenQ RL2455HM 60Hz 24.0" Monitor  (Purchased For $0.00)
Case Fan: NZXT FX-140LB 98.3 CFM 140mm  Fan  ($15.98 @ OutletPC)
Keyboard: Razer Blackwidow 2014 Wired Gaming Keyboard  (Purchased For $0.00)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  (Purchased For $0.00)
Headphones: ROCCAT Kave XTD 5.1 Premium 5.1 Channel Headset  (Purchased For $0.00)
Other: Corsair HG10 N1 ($39.99)
Total: $898.87
https://linustechtips.com/topic/180815-upgrading-but-need-help/
Fan Mount Locations
Front: (x2) 120/140mm
Top: (x2) 120/140mm
Rear: (x1) 120mm
Fans Included
Front: (x1) 140mm
Rear: (x1) 120mm
Radiator Mount Locations
Front: 240/280mm
Top: 240/280mm
Rear: 120mm
Compatible Corsair Liquid Coolers
H55, H60, H75, H80i, H90, H100i, H110
Source: http://www.corsair.com/en-us/obsidian-series-350d-windowed-micro-atx-pc-case
When it says "Front: (x2) 120/140" Does that mean it has 2 140's or 1?
https://linustechtips.com/topic/180815-upgrading-but-need-help/#findComment-2428261
