i wanted to build a 4k pc but i don't think i have enough money now so i decide to go with this build which i would upgrade to 4k when i get more money so i need your help telling me if this is ok and what i will need to upgrade to reach 4k gaming.
PCPartPicker part list: http://pcpartpicker.com/p/JcHGbv
Price breakdown by merchant: http://pcpartpicker.com/p/JcHGbv/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($339.99 @ Amazon)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($59.99 @ NCIX US)
Motherboard: Asus MAXIMUS VII RANGER ATX LGA1150 Motherboard
Memory: G.Skill Sniper Series 16GB (2 x 8GB) DDR3-2400 Memory  ($159.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.99 @ SuperBiiz)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($77.98 @ OutletPC)
Video Card: Asus GeForce GTX 780 3GB DirectCU II Video Card  ($460.00 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($119.98 @ OutletPC)
Power Supply: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($140.98 @ Amazon)
Optical Drive: Asus BW-16D1HT Blu-Ray/DVD/CD Writer  ($77.27 @ NCIX US)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($94.99 @ NCIX US)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($249.23 @ Amazon)
Total: $1890.39
my budget was 2200 american dollars i also want to ask if the gtx780 is enough for 1080p gaming at high settings or ultra . If you think of abetter build fill free to send it to me all the help will be appreciated. And also if you make i build i don't want liquid cooling and only want a nvedia gtx card   and tell me if this is optimised for silence too pls  i am so confused right now
https://linustechtips.com/topic/179924-my-first-pc-build/
I think we've been over this before. 4k is not worth it at the current time because you need to spend a lot more money to have the horsepower to game at that large of a resolution.
Don't buy Maximus boards because they're a waste of your money for what you'll do with it.
Aside from that your build looks fine.
https://linustechtips.com/topic/179924-my-first-pc-build/#findComment-2417030
-snip-
This isn't even close to handling 4k. You'll want the VRAM of a Titan or a 290X.
Buying the 290X will leave you in a cheaper position to upgrade, unless you want to fork over $1,000.
Just save your pennies and buy once. Or play in 1440p, if you want high-res games.
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/179924-my-first-pc-build/#findComment-2417042
Get a Windows key from G2A, around $30.
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($164.99 @ Amazon)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($129.99 @ Amazon)
Video Card: Sapphire Radeon R9 290X 4GB Vapor-X Video Card  ($620.69 @ Amazon)
Case: Corsair 760T Black ATX Full Tower Case  ($129.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.99 @ Newegg)
Monitor: Asus PB278Q 27.0" Monitor  ($476.99 @ Amazon)
Total: $2208.57
https://linustechtips.com/topic/179924-my-first-pc-build/#findComment-2417084
Total: $1890.39
Like people said, Maximus is over priced
And you won't be able to play 4k with that setup, and trying to build a computer that will is pretty stupid at this point in time...
And yes, for 1080p 780 is enough for most games on ultra (but games with bad optimization will always be a problem to run, no matter the hardware).
And why do people insist on an that and that card... Unless you need something that only it can offer (for Nvidia shadowplay...), you chose something with more "bang for the buck", and 290x is comparable to 780ti, and beats it at resolutions higher than 1080p because it has more VRAM...
Here's a build:
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($149.99 @ NCIX US)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($144.99 @ Amazon)
Video Card: MSI Radeon R9 290X 4GB TWIN FROZR Video Card  ($489.99 @ Newegg)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ NCIX US)
Total: $2024.38
Now, i put that PSU because if you really want to game on 4k, you'll need 290x CF, and that PSU can handle it. And you'll need more VRAM for 4k. So, while this an 1080/1440p build, you'll be able to upgrade it to be able to somewhat play some games on 4k...
https://linustechtips.com/topic/179924-my-first-pc-build/#findComment-2417124
