Hello forum members,
today I recieved my new R9 290X DCUII. When I installed it my PC wouldn´t boot. So I tried out different things, bought a PSU tester and so on.
Then I went into the BIOS to check voltages to compare it to the tester. I went out without changing anything and it started booting correctly.
So it is until now. Everytime I go into BIOS before booting it works, if not, it doesn´t.
It is not that big of a deal, I would go and sent it back, but if there is a way to go around it it would be nice.
Thanks for the help.
https://linustechtips.com/topic/179743-gpu-boot-problem/
Try updating your bios.
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2414773
I´m sure it is. When I go into BIOS first everything works fine. Only when I don´t it wouldn´t work. It goes up till the loading screen of windows and then the screen turns black and mouse and GPU leds turn off.
Is the 6/8pin connectors attached properly? Try to unplug them and plug them back in.
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2414826
I understand the issue, lets try something else. In the BIOS change the boot order so your primary boot HDD or SSD isn't there at all. Save the settings and restart your computer. You'll get a message saying there's a missing OS but once you see that restart anyway and now boot back into the BIOS. Now make your normal boot drive back to the primary. Save the settings, restart, and see if it works.
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2414896
Idk if it's this, but the high-end DCUII cards have had a lot of issues.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2414901
Ok, tried it out but unfortunately it didn´t work. Any other ideas?
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2415012
Okk, I´m back from trying it out. Problem is still there. Pretty strange problem I guess.
Yeah it is pretty strange. Can you try to clear your CMOS? Unplug everything from your computer and take out the battery on your motherboard, leave it out for at-least a minute and put it back in.
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2415132
I have a clear CMOS button, is that ok as well?
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2415142
Since we've tried just about everything, you can try what lani recommended initially of updating your BIOS.
Thank you very much guys! This actually worked. Now I´m a much happier user. I can just say thanks again.
https://linustechtips.com/topic/179743-gpu-boot-problem/#findComment-2415360
