PC BSoD - Need Help with Debugging/Diagnosing
Go to solution Solved by Yamuda,
Was able to debug it myself.
TL;DR - Corrupted memory.
Microsoft ® Windows Debugger Version 6.3.9600.17029 AMD64
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Andal\Desktop\071114-12745-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*C:\SymCache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18409.amd64fre.win7sp1_gdr.140303-2144
Machine Name:
Kernel base = 0xfffff800`02a5a000 PsLoadedModuleList = 0xfffff800`02c9d890
Debug session time: Fri Jul 11 11:30:03.437 2014 (UTC - 7:00)
System Uptime: 0 days 0:37:20.452
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 109, {a3a039d8957167b7, b3b7465ee7ee370d, fffff80002e09426, 1}
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : memory_corruption
Followup: memory_corruption
0: kd> !analyze -v
CRITICAL_STRUCTURE_CORRUPTION (109)
This bugcheck is generated when the kernel detects that critical kernel code or
data have been corrupted. There are generally three causes for a corruption:
1) A driver has inadvertently or deliberately modified critical kernel code
2) A developer attempted to set a normal kernel breakpoint using a kernel
 debugger that was not attached when the system was booted. Normal breakpoints,
 "bp", can only be set if the debugger is attached at boot time. Hardware
 breakpoints, "ba", can be set at any time.
3) A hardware corruption occurred, e.g. failing RAM holding kernel code or data.
Arguments:
Arg1: a3a039d8957167b7, Reserved
Arg2: b3b7465ee7ee370d, Reserved
Arg3: fffff80002e09426, Failure type dependent information
Arg4: 0000000000000001, Type of corrupted region, can be
0 : A generic data region
1 : Modification of a function or .pdata
2 : A processor IDT
3 : A processor GDT
4 : Type 1 process list corruption
5 : Type 2 process list corruption
6 : Debug routine modification
7 : Critical MSR modification
Debugging Details:
FAULTING_IP:
nt! ?? ::NNGAKEGL::`string'+17e50
fffff800`02e09426 83fb01          cmp     ebx,1
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  CODE_CORRUPTION
BUGCHECK_STR:  0x109
PROCESS_NAME:  System
CURRENT_IRQL:  0
ANALYSIS_VERSION: 6.3.9600.17029 (debuggers(dbg).140219-1702) amd64fre
STACK_TEXT:
fffff880`02fe1598 00000000`00000000 : 00000000`00000109 a3a039d8`957167b7 b3b7465e`e7ee370d fffff800`02e09426 : nt!KeBugCheckEx
STACK_COMMAND:  kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
    fffff80002e0946c - nt! ?? ::NNGAKEGL::`string'+17e96
[ 74:76 ]
1 error : !nt (fffff80002e0946c)
MODULE_NAME: memory_corruption
IMAGE_NAME:  memory_corruption
FOLLOWUP_NAME:  memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP:  0
MEMORY_CORRUPTOR:  ONE_BIT
FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_ONE_BIT
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:x64_memory_corruption_one_bit
FAILURE_ID_HASH:  {2dbb898e-c425-bad1-90fe-71c78117521f}
PC has been unexpectedly shutting down lately (like every couple hours or so, it will crash). Even without any programs open. I have already scanned it with multiple programs for malware and it seems to be super clean now.
Problem signature:
  Problem Event Name: BlueScreen
  OS Version: 6.1.7601.2.1.0.256.48
  Locale ID: 1033
Additional information about the problem:
  BCCode: 109
  BCP1: A3A039D89567E558
  BCP2: B3B7465EE7E4B4AE
  BCP3: FFFFF80002E09453
  BCP4: 0000000000000001
  OS Version: 6_1_7601
  Service Pack: 1_0
  Product: 256_1
Files that help describe the problem:
  C:\Windows\Minidump\071114-13119-01.dmp
  C:\Users\Andal\AppData\Local\Temp\WER-36145-0.sysdata.xml
Read our privacy statement online:
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
The WE-36145-0.sysdata.xml file wasn't in the folder so I chose 2 files (a dmp and xml) that were created at the same time, since this problem has been on-going for the past couple days now. If you really want this exact dmp file (without the xml) then I can upload it, just let me know. Thanks.
dmp: https://mega.co.nz/#!sYx2FLQQ!c8i4lPf4_0eERvNVAjdieIiid7OHuzYRVGeWF-hUlnA
xml: https://mega.co.nz/#!oFxxhKbB!mid_Xm7kMw2sJvqOqpdFE8A_x0AVO6OMUGiJcu1j6JY
https://linustechtips.com/topic/179709-pc-bsod-need-help-with-debuggingdiagnosing/
Machine Name:
0: kd> !analyze -v
Arguments:
2 : A processor IDT
3 : A processor GDT
Debugging Details:
FAULTING_IP:
BUGCHECK_STR:  0x109
CURRENT_IRQL:  0
STACK_TEXT:
STACK_COMMAND:  kb
[ 74:76 ]
ANALYSIS_SOURCE:  KM
