Okay so I am moving houses and have to purchase a new router. I was planning on buying the Linksys WRT1900AC. I had some questions, can I hook up broad band internet to this and have wifi throughout the house? Also it has sata 3 and usb ports. Would it be faster for me to use an usb to ethernet for the connection to my desktop?
https://linustechtips.com/topic/179474-router-help/
the usb ports are for drives/other peripherals.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/179474-router-help/#findComment-2411194
http://linustechtips.com/main/topic/178461-how-to-build-your-own-router-using-soekris-and-openbsd/
Buying routers is for sissies.
If you don't do that, the WRT1900AC is one of the best OTS solutions and you can even install OpenWrt and hopefully LibreWRT eventually.
"You have got to be the biggest asshole on this forum..."
-GingerbreadPK
sudo rm -rf /
https://linustechtips.com/topic/179474-router-help/#findComment-2411198
Dude Im sorry i have no clue what OTS solutions OpenWrt or LibreWRT is.. and I wanted a router cause my mom and sister live there to and they both use wifi.
https://linustechtips.com/topic/179474-router-help/#findComment-2411311
just get a linksys dual band wireless modem router.
then hook up a wireless USB adaptor to your PC , case closed.
CPU: Intel i5-4670K CPU Cooler: Swiftech H240-X Motherboard: ASUS Z97 Sabertooth Mark 1 Memory: Corsair Vengeance Pro 1866MHz 16GB Storage:  Samsung 850 evo 250GB ,1TB WD BLUE, Seagate Barracuda 2TB GPU: ASUS STRIX GTX970 4GB Case: Fractal Design Define R5 PSU: Corsair AX760 Full Modular Monitor: Dell 23" S2340L IPS Keyboard: Corsair Strafe RGB Mouse: Logitech G502(w/ Mi Metal Mousepad) Headphone: Audio Technica ATH-M50/MSR-7 Speaker: Edifier Studio 7 R2730DB
https://linustechtips.com/topic/179474-router-help/#findComment-2411387
Don't be sorry, be curious.
OTS means off the shelf. I thought you were a serious enthusiast. The WRT1900AC is a great consumer-grade solution. Buy it if you want to, but I figured that since this is an enthusiast forum, you were looking for a hardcore, power user solution.
-GingerbreadPK
sudo rm -rf /
https://linustechtips.com/topic/179474-router-help/#findComment-2411389
The house I live in now I use wifi for my desktop and I cannot stand it the speeds are horrible even on 5g. I just need a router that can handle large file transfers and gaming. Also no one ever said the fastest way to connect my desktop and the router.. and i am not doing wireless. My computer has a good many Usb 3.0 ports open and 1 ethernet.
https://linustechtips.com/topic/179474-router-help/#findComment-2413624
In that case, just get a router. The WRT1900AC is a router and access point. You don't even really need to buy a router, you can make one out of any computer.
-GingerbreadPK
sudo rm -rf /
https://linustechtips.com/topic/179474-router-help/#findComment-2413639
