I currently have a reference GTX 660ti with a Kraken G10 and H55 cooler setup, but the pump is a little annoying at times and the setup is quite ghetto. If anything, I would like to get a cooler for the CPU and move the H55 onto my i5-4670k (Stock cooler is fine for a 4GHz overclock, but a little more with less noise would be good).
So whats a good option? Mostly thinking of a quiet air cooler, it doesn't have to perform the best, just overall decent temps and noise. No budget yet until I know how much they cost. Also if possible, the smaller the possible since the GPU is located on the middle of the card.
Thanks.
The Grey Squirrel
CPU: i7-6700k @ 4.8GHz - CPU Cooler: Be Quiet! Dark Rock 3 - Motherboard: ASUS Z170-E - GPU:  ASUS GTX 1060 DUAL
Case: Inwin 303 - RAM: 4x8GB Corsair LPX Storage: 2x Samsung 850 EVO 500GB - PSU: EVGA SuperNOVA G2 550W
Mouse: Logitech G502 Wired / Bungee Keyboard: Corsair Strafe Cherry MX Red Headphone: Sony MDR- 1R
Microphone:  Blue Yeti - Webcam: Logitech C920 - Monitors: 3x Dell S2415H
https://linustechtips.com/topic/179459-aftermarket-gpu-cooler/
I think Arctic Cooling makes a good aftermarket cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835186096
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/179459-aftermarket-gpu-cooler/#findComment-2411063
Hm, looks decent, but actually for that price I could try to find different radiator that's more silent?
The Grey Squirrel
https://linustechtips.com/topic/179459-aftermarket-gpu-cooler/#findComment-2411086
