Raid help
So if i raid a 120 and 240 together i can only use the 120 or 240. if i get a 120(another) and raid that would i end up with 240GB?
No, that is not what will happen. Look at it like this: Your smallest drive will be 120GB. If you were to run RAID 1 (redundancy) the 240GB drive would backup the 120 and you would still have 120GB of space. If you were to run RAID 0 (stripped) you would get a maximum of 240GB of space (double the smallest drive) and more or less double the speed also. If you were to run a second 120GB drive you would end up with 240GB also, double the 120 and double the read and write speed. The best solution in your case is to use the 240GB drive as an expansion as you end up with 360GB of space, without the risk associated with RAID 0 (and without the need to reinstall the OS which would be required with any RAID setup).
