Enthoo Pro Fan Placement
Solved by airdeano,
the enthoo pro can easily handle all intake as the case can naturally exhaust
the interior air. to aid in the process, the rear could be made to exhaust.
the pro is not an air tight chassis so more intake to exhaust is a better effect,
especially if using a GPU with non-reference cooling solution (pressure could
push the air from GPU to rear I/O)
dual 140 intake, dual roof intake or exhaust and rear I/O intake or exhaust.
