Hey guys,
Recently my laptop screen went extremely dark,it's near impossible to see unless I shine a flashlight on it so I assume the back lights are the issue.
When I first started doing some research into it the solution seemed to be a new inverter but after a bit more looking I found my laptop's screen is LED and that I most likely dosent have an inverter. After removing the bevel from my screen I found this to be true.
My question is how do I go about fixing this? Is the inverter equivalent for LED built into the screen meaning I need to get a new screen?
Thanks in advance for the help guys!
https://linustechtips.com/topic/179373-led-laptop-back-light-issues/
Just buy a new screen and replace it.It's a real simple repair, costly though.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
