Overclocking CPU Fan
Solved by Oshino Shinobu,
so i dont need to buy the cpu cooler if the max turbo clock is 4.1? or can i go past 4.1?
Is turbo clock the same as overclocking?
Turbo clock is essentially the CPU overclocking itself. You don't manually set it. The turbo clock is how much the CPU will speed up when it's needed, so it will be fine with the stock cooler.
Overclocking without an aftermarket cooler would be a bad idea.
