So my brother brought over his old 320GB laptop drive and he wanted me to get some files off of it. For some reason when i have the laptop drive plugged in my comp fails to load into windows. I know it's booting from my HDD because it's loading windows 7 and the laptop drive has windows vista.
I tried plugging it into a different SATA port and that didn't seem to do anything. The only thing i can think of now is unplugging the SATA cable on the laptop drive and plugging it in while the computer has booted into windows but i don't know if that's a bad idea.
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/178761-a-weird-problem-with-a-hard-drive/
Do you by chance have a usb to sata?
Well you could try plugging it in once your computer is at the windows 7 loading screen. Leave the power plugged in just plug in the data cable.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
Sata won't allow you to hot swap.-
You have to plug in both drives, and from the Bios /UEFI set what's the boot drive, and be sure it recognized both drives.
Yea i had both drives plugged in and clicked on the boot drive from the UEFI bios and it started loading windows 7 and just hangs on the windows 7 logo for 20 mins =\
I'm doing this on my HTPC this is the mobo in case anyone wondering - http://www.asus.com/Motherboards/H61MAUSB3/
That's weird. Don't you have a USB drive with a Linux distro around? Just boot from Live and mount the drives to recover the data
I will try that thank you.
I unfortunately don't have usb to sata cable but they seem handy so i'm gonna buy one right now. Thanks.
