so this is my build:
cpu: fx-4100
gpu: r7 260x 2 gb gddr5
psu: corsair cx430w
ram: 8 gb
1 500gb hdd
1 dvd drive
So is the cx430 going to handle this system in the long run? I have checked many similar builds where this gpu is used with cx430w but still im not sure because the manufacturer says it need 450w minimum.
https://linustechtips.com/topic/178648-will-this-build-work/
Welcome to the forum!
Unfortunately the build won't work because it's lacking a motherboard :P
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/ Read that and we'll help you come up with a list of parts.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/178648-will-this-build-work/#findComment-2398830
Well...you need a motherboard.  If you are planning on using those parts you will need a motherboard with the AM3+ socket.
It's all good now, your build will work fine. Try and get a better PSU if you can though, PSU is always a good investment it will give you the room to expand and upgrade and it can last you several builds too.
https://linustechtips.com/topic/178648-will-this-build-work/#findComment-2398878
Why get the FX-4100 when the 6300 is much much better and it is only 19 dollars more expensive.
SEE if this combo suits you. Honestly the ram and the FX6300 are amazing on this combo for a budget build.
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.1594324
Also the price difference from a 500g to a 1TB HD is not that big!
Alright, i just read your post. You should be ok
https://linustechtips.com/topic/178648-will-this-build-work/#findComment-2409229
