Hi,
So now i need a wireless headset under 200$, that's light weight,has to be light weight.
I've a kraken 7.1 it's good and all but 2 heavy & to tight,from amazon, Approximate Weight: 340g.
also have a Sony stereo headset it's light, but it's dying now.
Was going to get bluetooth headphone but need the mic.
Getting headaches from the kraken.
Had a logitech g930, it was perfect for me, but mic broke in like 2 days & at 60% volume it starts getting a hiss sound, also with the kraken.
https://linustechtips.com/topic/178445-wireless-headset-under-200/
Wireless will always be heavier because they have to put in the receiver. Wired is better for that especially because wireless is bad for audio and headsets are bad for audio and put together they are double as bad. Headphones and mic would be better but the one exception is the Kingston HyperX Headset.
hyper x headset has good reviews.
I was normally going to buy the m40x but that's 240g not sure if that's heavy, & idk if they are comfortable.
With the modmic. I can go none wireless as long as the cord is 9feet+.
They are light enough, or they distribute their weight well enough.
