you can check CPUWorld i5 Core 4690K for the estimate of the max operating temps
http://www.cpu-world.com/CPUs/Core_i5/Intel-Core%20i5-4690K.html
it say it around 72.72°C
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/175557-throttle-temp-for-4690k/#findComment-2346754
Thats the Tcase, thats just measured for the TDP.
Throttle temp is a few degrees of the Tjmax (which is 102°) so lets say around 97°
https://linustechtips.com/topic/175557-throttle-temp-for-4690k/#findComment-2347918
I stand corrected
new Intel can run that high?
https://linustechtips.com/topic/175557-throttle-temp-for-4690k/#findComment-2347938
