Case and PSU?
Go to solution Solved by Morfy,
Yeah, Your build will draw like 350W, so it will be just fine. And the dual 660 test was done on a 5ghz i5 2500k, while stresstesting the system at max. You are safe.
the v550 is overpriced. i suggest a cx600m and a corsair 230t.
also a full budget helps
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342485
I really love my 300r, so I personally would get the cx600m and 300r, I dont like the 200r, the 230t is another good option!
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342508
Awesome, thought that the CX600m was crap. With the money I save I can get the 200r or even the 230t, that case is so awesome :D
EDIT: About budget... I live in Mexico, so PcPartPicker and that stuff is useless because hardware here is very expensive :(
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342529
I have the cx600m and 200R for my brother's build, and they are ok, the case looks very good with the plain theme, like a more expensive case. The psu is good, took on 2 gtx 660s no problem.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342538
I also don't like the 200r, the 230t is cheaper than the 300r, and have LEDS. At least the 230t have more ventilation than the 200r...
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342542
the 230t is a creat budget case for air cooling but if you want to water cool than a 300r has more support
My Rig
Total: $2074.22
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342557
Wow, guess that it will power my build without any problem.
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342569
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342678
Keep it clean of dust and it will be just fine.
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2342710
The "rated at 30°C" doesn't matter? I've been reading some reviews and some opinions and a lot of people says that isn't worth it :( I'm very confused. I've got some extra money, I can spend it in a new monitor (Currently a 17"1440x900), or a better PSU like GS600 or V550.
I'm very confused, also about the case, the 912 is way cheaper but the 200r and 300r seems pretty good.
Pretty damn confused.
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2348005
On the case matter, just pick what looks better to you, you will look at it daily..
https://linustechtips.com/topic/175445-case-and-psu/#findComment-2355478
