Hey! In the last few weeks the mic on my g930s likes to reset its volume, in the sound preferences, down to 20 (out of 100) Every time i turn my computer off or restart it it goes down to 20. i constantly have to go put it back up to the volume i want. I have no clue why it started doing this and i have no clue how to keep it and the volume i want, does anyone have any clue why it is doing this and how to fix it?
https://linustechtips.com/topic/175030-mic-volume-resetting/
If windows thinks it is a "new device" every time it loads, it will basically reinstall the drivers and have default settings loaded up. Can you try leaving the headset plugged into a different USB port?
https://linustechtips.com/topic/175030-mic-volume-resetting/#findComment-2334289
