Whats causing this?
When i install win7 or win8 and they both have the same problem.
But the problem comes out only when i install geforce drivers.
When i dont install geforce drivers, then i dont have the problem.
Only way to get rid of this problem is, that i have to change the windows theme to windows 7 basic.
But in windows 8, their is no basic theme and the aerolite dont do nothing.
The GPU is ok. It works fine in other pc´s.
Before GTX 660ti i had GTS 8800 and their was no problem.
Is this really somekind of compatibility issue.
My system is little bit old.
Intel Q6600
Gigabyte GA-P35-DS4 rev 2.0
Corsair XMS 800mhz 1Gb x 4=4Gb
Gainward GTX 660ti, 2Gb Ram
Corsair CX500 PSU
post-22160-0-33659900-1404301045_thumb.j
https://linustechtips.com/topic/174807-artifact-problems/
Could be the VRAM. Without GeForce drivers installed it runs off system RAM does it not? (Correct me if I'm wrong)
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/174807-artifact-problems/#findComment-2326516
