I was hoping you guys would be able to help me out with my first gaming rig and tell me if it sucks or not. It would be a great help.
Intel Core i5-3470 Ivy Bridge Quad-Core 3.2GHz (3.6GHz Turbo Boost) LGA 1155 77W Desktop
WD Blue WD10SPCX 1TB 5400 RPM 16MB Cache SATA 6.0Gb/s 2.5" Internal Notebook Hard Drive
EVGA SuperClocked 02G-P4-2765-KR GeForce GTX 760 2GB 256-bit GDDR5 PCI Express 3.0 SLI Support w/ EVGA ACX Cooler Video Card
SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE
ASRock Z97 Pro4 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000)
And then I was thinking about liquid cooking the CPU. Any advice helps and be critical if you have to. I want to get it right. Thank you.
https://linustechtips.com/topic/174572-my-first-build/
Budget? Country? Uses?
And you do know that that Mobo and CPU aren't compatible...
https://linustechtips.com/topic/174572-my-first-build/#findComment-2318725
The motherboard and CPU are not compatible. Get a 4570 or 4670. Those will work.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/174572-my-first-build/#findComment-2318733
budget?
location?
uses?
Specs
https://linustechtips.com/topic/174572-my-first-build/#findComment-2318913
Okay so how about this?
Intel Core i5-4750 Haswell Quad-Core 3.2GHz LGA 1150 84W
https://linustechtips.com/topic/174572-my-first-build/#findComment-2318983
I would prefer it to stay under 1k but it's okay if it goes a little over. I'm from the US and I'll probably be using it mostly for gaming.
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($149.98 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ OutletPC)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($113.98 @ OutletPC)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($76.99 @ Amazon)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($64.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.91 @ OutletPC)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($359.99 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($109.99 @ Micro Center)
Power Supply: NZXT HALE82 V2 700W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1018.80
Specs
https://linustechtips.com/topic/174572-my-first-build/#findComment-2319043
Total: $1018.80
How would you say this build would do on I don't know Battlefield 4?
https://linustechtips.com/topic/174572-my-first-build/#findComment-2319851
it has a 290...
so yea search up some benchmarks but easily high/ultra 1440p 40+fps
Specs
https://linustechtips.com/topic/174572-my-first-build/#findComment-2320023
