Hey Forum,
I'm gunna be picking up a Noctua NH-D14, But i'm worried that the air flow in my R4 will get disrupted because the cooler is so big.
Current Fan orientation:
Intakes
2x 140mm front
1x 140mm side
1x 140mm bottom
Exhausts
2x 140mm top
1x 140mm rear
Any recommendations for different fan setups are welcome.
I was thinking about doing a rear intake and have the NH-D14 pull from the back with the top also changed to intakes and front to exhausts.
https://linustechtips.com/topic/174085-define-r4-fan-orientation/
I would go with the same intakes and change the rear to intake aswell.
4770k Delid @ 4.5Ghz/1.25V w/ NH-D15, Maximus VII Hero, HyperX Beast 8GB 1600Mhz, GTX770 DCII OC, Strider Gold S 750W, 120GB 840 EVO, 2TB Barracuda, No case : D
Quickfire TK (MX Brown), Naos 7000, 128GB Surface Pro 2, 32GB G2 With Lightning Rom V4
You don't need that many fans, especially the side intake, unless you are running two or more high end AMD video cards.
One of the main selling points of the Define R4 is the sound dampening performance.  If you max out on fans, you essentially nullify that benefit.
Intakes
2x 140mm front
1x 140mm bottom
Exhausts
1x 140mm rear
That's what I would suggest.  Test out both configurations and note the temp differences and noise difference.
Hey Forum,
Intakes
2x 140mm front
1x 140mm side
1x 140mm bottom
Exhausts
2x 140mm top
1x 140mm rear
Long story short, make all the fans intake except for the rear (keep it as exhaust)
"Rawr XD"
Your orientation sounds perfect as it is.
My old orientation was the exact same as what you're planning and it worked a treat (now I'm missing a top exhaust but that'll be resolved soon enough).
I disagree with having only one exhaust with 4 intakes.
