Get NF-A14's.
https://linustechtips.com/topic/173996-what-fans/#findComment-2310660
If you like poop colored fans :D
Like me, the OP likes Noctua fans.
Don't forget the barf--it's barf beige and poop brown.
https://linustechtips.com/topic/173996-what-fans/#findComment-2310745
What about the new noctua fans? U know the ones that dosent look like poop?
They aren't as quiet as the normal versions but perform well and are quite expensive.
https://linustechtips.com/topic/173996-what-fans/#findComment-2333493
