Hey guys,
Im getting my replacement h80i back in the next 2 days after my h80 pump became unhappy with life, and due to my error my SP120s went to corsair with it and they arent coming back.
I have the NZXT H440 and am wondering if I should just keep the stock h80i fans, buy some more SP120s or get the Noctua iPPC pressure optimisted fans (dont know the name/number) or if anyone has other recomdations on fans for the h80i.
I dont want to spend more then $100 NZD ($87ish USD) for the pair, i want them to be quite and preform well and lastly to not be brown.
MoBo: GA-z77x-ud3h CPU: 2500K @ 3.1 (miss my h80) Cooler: Stock GPU: EVGA 780 ACX RAM: 8gb G.skill SSDs: 2X Sammy 120EVOs HDDs: 2x Seagate Barracudas PSU: Corsair RM750 Case: Blue NZXT H440
https://linustechtips.com/topic/173724-h80i-fans/
Wha-whaaat? Did i understand that correctly, you send them your H80 with your own fans back and they are giving you a unit with stock fans? That's messed up! :D
Bitfenix Spectre Pro (non PWM) are a good compromise between money/silence/performance.
who cares...
https://linustechtips.com/topic/173724-h80i-fans/#findComment-2307311
Yeah im confused too, but ohwell the old SP120s wernt PWM so ran at 100% all the time. im not sure how the fan control works on the h80i wether i need PWM or not
https://linustechtips.com/topic/173724-h80i-fans/#findComment-2307349
