Hello All, I am about to order my water cooling parts, and I just need the fittings. I picked out which ones I want, but I cant find anywhere that says if its just 1, or if its multiple. Can someone clarify?
Product - http://www.amazon.com/XSPC-Compression-Fitting-Chrome-Finish/dp/B00ILDUF12/ref=pd_cp_pc_3
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/173527-compression-fittings/
thats one, fitings are generally expensive
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/173527-compression-fittings/#findComment-2304765
That's just one. Usually, that's the average price of quality fittings. If you get the cheaper hardware store fittings, you're going to save money, but it's not going to look as good or be as safe to use compared to XSPC or Bitspower for example.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/173527-compression-fittings/#findComment-2304779
Well then. Glad I went 50 Bucks below budget...
Follow up question. How many would I need if I had a CPU block, 360mm Rad, and a Pump/ Tank combo?
Rad - http://www.amazon.com/XSPC-EX360-Performance-Radiator-Supports/dp/B006097HEC/ref=sr_1_1?ie=UTF8&qid=1403750700&sr=8-1&keywords=XSPC+360mm
Res/Pump - http://www.amazon.com/XSPC-X20-Pump-Reservoir-Combo/dp/B00A42X2KY
CPU Block - http://www.amazon.com/XSPC-Raystorm-Block-Intel-Socket/dp/B005T01B54/ref=sr_1_1?s=electronics&ie=UTF8&qid=1400111565&sr=1-1&keywords=xspc+waterblock
If I did my math right it should be 6. Is that right? and should I get extras if I ever, say water cool my Mobo?
(Ohh, and can I get a link to a decent Anti Corrosive? I cant find any on Amazon.)
sex hahaha
https://linustechtips.com/topic/173527-compression-fittings/#findComment-2304796
Yes, 6. Don't get extras until you're ready to expand your loop. I'd cool my GPU first before cooling my mobo. Ram cooling is pointless. Anti-corrosive? You don't need one. Unless you mean a biocide in which case this http://www.amazon.com/Petras-Tech-Nuke-Concentrated-Biocide/dp/B008EGYJ54/ref=sr_1_1?ie=UTF8&qid=1404076904&sr=8-1&keywords=pt+nuke    + this http://www.frozencpu.com/products/21502/ex-tub-2080/Monsoon_999_Fine_Silver_Bullet_Antimicrobial_G_14_Plug_-_Chrome_MON-PLUG-AG-CH.html
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/173527-compression-fittings/#findComment-2304921
