Hi,
I'm planning to build my first PC in the coming 2-3 weeks (if budget goes to plan). DOes anyone have any thoughts on what I could change in it? I am going for the $1200-1300 price range.
PC Link: https://docs.google.com/spreadsheets/d/1g54TV1N43zvegfIHlNeCuj65pLpaZMCoX6_HPu562Xk/edit?usp=sharing
Thanks
Gamer, Programmer and Server Administrator
all with a HP laptop <3
https://linustechtips.com/topic/173138-thoughts-on-pc-build/
Why 16GB of ram? Also it's really handy if you use PCpartpicker for your parts list.
N64 HTPC: [Completed]
Main PC: i7 4770k @ 4.2 Ghz | Be Quiet! Dark Rock TF | Asus Z87 Maximus VI Formula | G Skill Ripjaws X 16GB | Zotac GTX 1070 | Samsung 850 EVO 500GB | Seagate 1TB Hybrid | Samsung 840 EVO 128GB | Corsair 1200i | Thermaltake Core P5
https://linustechtips.com/topic/173138-thoughts-on-pc-build/#findComment-2300318
I want to use it for rendering video aswell and 3d work. http://nz.pcpartpicker.com/p/7rTTzy I use docs cause PCPartPicker doesnt have updated prices from other stores
https://linustechtips.com/topic/173138-thoughts-on-pc-build/#findComment-2300335
I'd suggest planning a bit later. ~2-3 days at most before you buy. Parts and prices change frequently so any parts list you come up with now will likely be obsolete by the time you're ready to buy.
https://linustechtips.com/topic/173138-thoughts-on-pc-build/#findComment-2311976
