Budget Build. Help!
Go to solution Solved by wildy,
Hi, I plan on building my first rig just to do some gaming and editing, I don't have any specific games in mind, and i'm on a budget.
1. Budget and Location.
United States, I have a Budget of $750 or Under.
2.Aim.
I plan to use the system for some gaming, and some light photo editing.
3. Monitor.
As of right now I plan on running only on one monitor, but i do plan on adding another monitor in the future. As for resolution i'm not quite sure.
4.Peripherals
I already own peripherals, but Windows 7 or 8 is included in the price.
I do plan on upgrading the rig in the near future too if this helps  :).
if the near future is less than 4 months save and buy the pc later
United States, I have a Budget of $800 or Under.
2.Aim.
3. Monitor.
4.Peripherals
https://linustechtips.com/topic/172601-budget-build-help/
2.Aim.
3. Monitor.
4.Peripherals
https://linustechtips.com/topic/172601-budget-build-help/#findComment-2294188
arrghhh comic sans
CPU: Amd fx 8120 3.9ghz...Motherboard: Asus m5a97 evo R:2.0...RAM: 8gb 1600 kingston hyperx blu...GPU: XFX R9 280x ...CASE: Nzxt h440...
HDD: Kingston adata ssd 500 gigs, wd blue 500gb...PSU: Corsair gs700...Monitors: Asus vk222h Cooler: Noctua nh-d14...Keyboard:coolermaster masterkeys m...Mouse: logitech g300...Headphones: Logitech g430
https://linustechtips.com/topic/172601-budget-build-help/#findComment-2294190
but yeah save, start your build in like february 2015 or something
https://linustechtips.com/topic/172601-budget-build-help/#findComment-2294196
something like that idk :|
https://linustechtips.com/topic/172601-budget-build-help/#findComment-2294204
there is this button called the 'edit' button, use it sometimes instead of triple posting.
yes, if the near future is december ish, wait for maxwell which is rumored to be released then
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/172601-budget-build-help/#findComment-2294262
