When you delete the render files in a project. do you delete all of the files (all progress in the timeline lost?)?
I7-6700k, Asus Maximus VIII Formula, 2 x 8GB Corsair Dominator Plantinum ram, ASUS GTX 960 STRIX, sound blaster zx, 1TB boot drive ssd, 128GB/256GB storage ssd, 1TB storage HDD, 4TB of storage (backup),Windows 10 Pro,1000w psu
https://linustechtips.com/topic/170334-premiere-pro-cc-inquiry/
By render files do you Pre-rendered files or Files rendered from premiere?
I mean files rendered (not exported) to make the playback in the sequence playback panel go smoothly.
https://linustechtips.com/topic/170334-premiere-pro-cc-inquiry/#findComment-2263883
oh well i Don't know about premiere but in after effects if i delete those files, when i open the project again after effects will automatically re-render them, unless i moved or deleted the original files
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
https://linustechtips.com/topic/170334-premiere-pro-cc-inquiry/#findComment-2263893
