so before i buy my new Gaming PC i will do a system upgrade (a10 7850k,a mini tower case,8GB 2133 mhz ram and other stuff) and i will keep it as a 2nd build. its specs will be
a corsair 250D most likely, or a coolermaster silencio
an a10 7850k
an asus mobo fm2+ at 55EUR
2133 MHZ of corsair vengeance
120GB SSD
cx 500M
and to cool the apu i will need your suggestions
also as a much later upgrade if i need it an msi r7 265.
opinions? i havent calculated the exact budget but it is relatively cheap
https://linustechtips.com/topic/170140-mini-itx-2nd-build/
i need the a10 because i will get it soon... the parts in my pc are dying (the gpu performs terribly)
Why do you need it? Can't you not get it soon? :)
At the similar pricepoint this build will have far more performance, the A10 CPU still doesn't offer that much performance in games, and the integrated graphics, while better than others, are still overpowered by a dedicated GPU. The i5 and the R9 270X will give you much better fps in games.
https://linustechtips.com/topic/170140-mini-itx-2nd-build/#findComment-2261648
perhaps you are right....
https://linustechtips.com/topic/170140-mini-itx-2nd-build/#findComment-2261808
