I am helping a friend setup a private mybb forum and when installing the template I noticed this. Not so much a massive problem, but I think you would agree it's going to look better If i can get this fixed.
The Posts: 1 has been bumped to the side. If anyone know how to fix this it would be a massive help.
Thanks in advance, Red.
Things I have tried so far.
*Image resize
*removing the rep text to see if it would change the position of the Posts text.
Connor Freebairn - ConnorFreebairn@newman.cumbria.sch.uk
IT Technician & Certified computer geek.
https://linustechtips.com/topic/169812-mybb-help/
Did it occur after you added the staff title?
@Joshuam08 - ex MyBB support staff; you are needed.
If Joshuam08 would help me that would be awesome. I appreciate any help I can get with this problem. I will send him a pm.
Might be in the template. Not sure how does the code go, but i think there are some callers wich ask for like picture and stuff. You are missing one <br> in there.
Thanks, I will look through the template files now for anything regarding an image. Any idea which file?
https://linustechtips.com/topic/169812-mybb-help/#findComment-2259400
Fixed the problem.It was just as Jantso said, I needed an extra set of "<br></br>" in the template.
Here is what Ive added. Now the template works great. Thanks for the help guys.
https://linustechtips.com/topic/169812-mybb-help/#findComment-2259414
