Hey,
im new here hoping for some help with a build,i already have a build in mind and would love to hear your input and suggestions if i should change anything.my budget is around 2000-2500 $
Im from israel so the prices here are different.
Another big question which i have is if i should get the NH-D14 or the H110,the problem with the nh-d14 is the clearance and the fact it is huge and bulky and leaves about no space to do anything in the case incase i need to,about noise as i understand the nh-d14 is quieter rather than the H110
another question is if i should take the Asus Z97 Hero or the Asus Z97-A,will there be a difference in ocing,temps?
Intel Core i7 4770K 3.5Ghz 8MB L3 Cache s1150 - Tray
‏Corsair Hydro H110 280mm Extreme Performance Liquid CPU Cooler
‏Asus Maximus VII Hero LGA1150, Intel Z97, DDR3 1600, 3xPCI-E, VGA, DVI, HDMI‎
Corsair Vengeance Pro 2x8GB DDR3 1866MHz CL9 Kit CMY16GX3M2A1866C9
‏Asus GTX780 OC 3GB GDDR5 DX11 2xDVI HDMI DP PCI-E GTX780-DC2OC-3GD5‎
Samsung 840 EVO Series MZ-7TE250BW 250GB SSD SATA III
‏Seasonic 750W Gold X-Series Active PFC 12cm Fan Modular PSU X-750 (Retail)‎
Corsair Obsidian 750D Full Tower Case with Window No PSU
I am Planing on ocing the system btw.
Thanks a lot ahead to anyone that helps.
https://linustechtips.com/topic/169513-build-help/
location?
uses?
please read before posting
http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
use the quote button if you want my help
Specs
https://linustechtips.com/topic/169513-build-help/#findComment-2253961
location?
uses?
1. Budget & Location
Israel,budget as i said is about 2500 USD which is 8500 ILS
2. Aim
Mainly Gaming and some music editing and production
3. Monitors
currently running a 23" Dell Ultrasharp...planing on getting a 27" later on
4. Peripherals
I already have an OS and other peripherals such as keyboard,mouse.
5. Why are you upgrading?
Old pc just died.
https://linustechtips.com/topic/169513-build-help/#findComment-2254042
2. Aim
3. Monitors
4. Peripherals
Old pc just died.
ahh alright sorry about the location my bad however id look into something like this
note i'm using the us link so you can have a list of everything
not including a monitor or peripherals because its all personal so ill let you make up your mind
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($239.99 @ Newegg)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ NCIX US)
Motherboard: MSI Z97 MPOWER ATX LGA1150 Motherboard  ($192.99 @ Amazon)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Amazon)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($134.99 @ Best Buy)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($77.99 @ NCIX US)
Video Card: MSI Radeon R9 290X 4GB LIGHTNING Video Card  ($684.98 @ Newegg)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Corsair RM 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Amazon)
Total: $1680.90
Specs
https://linustechtips.com/topic/169513-build-help/#findComment-2254050
Thanks a lot for the reply,any feedback about the questions?
"Another big question which i have is if i should get the NH-D14 or the H110,the problem with the nh-d14 is the clearance and the fact it is huge and bulky and leaves about no space to do anything in the case incase i need to,about noise as i understand the nh-d14 is quieter rather than the H110
another question is if i should take the Asus Z97 Hero or the Asus Z97-A,will there be a difference in ocing,temps?"
https://linustechtips.com/topic/169513-build-help/#findComment-2265628
