restart your modem. Works magic, Last week i was getting 3MBps when I pay for 30, restarted it and apparently my ISP upgraded the infrastructure and doubled my speeds.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/169226-internet-speed-problem/#findComment-2250482
Sometimes it could be to do with a loose connection - make sure everything is securely placed. If that doesn't do anything as well as the comment above, it may be possible you have a faulty ethernet port. This happened to me, however it can be easily fixed by using a third party pci card.
https://linustechtips.com/topic/169226-internet-speed-problem/#findComment-2250547
As well as the questions above have you looked to make sure its not your connection wired or wireless to your gateway ( router). You can do this by opening a command prompt in windows as the administrators and running the following:
ipconfig
Look for the gateway IP address ( This is the IP of your router)
Then do --> ping 192.168.0.1 ( or what ever the IP address is)
Then paste the results here as a check :)
https://linustechtips.com/topic/169226-internet-speed-problem/#findComment-2253556
