Hello Guys.
As the title says, I'm interesting in knowing what the system requirements would be to stream HD with 40-60 FPS would be through OBS -> Twitch.
not just your system but your internet
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
OBS? You want Intel. Probably an i5. Intel QuickSync is your friend.
As I have AMD right now, and switching to intel once z97 gets official, I have no idea what's the best for intel, haha :D
So QuickSync is recommanded as for intel use ?
So the system requirements is not that important ?
The CPU and your internet speed are the two major factors.
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
You want a minimum upload speed of 5Mb/s and at least a quad core CPU since streaming (just as recording) will put a heavy strain on your system as well
current build and total cost   http://linustechtips.com/main/topic/150083-thrift-shop-build/
I apologize for my crappy English I'm American
Thanks a lot guys. So the future i5-4690k would do the job ?
Yes that would be very capable to stream.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
It actually depends on what you want to play and stream at the same time.
I have an i5 4670K and when i try to play cs go and stream at the same time i go from 290 fps to 140 fps.
This is with screen tearing and a serious lag in my game.and it's not my upload speeds cause i have 8 mb up and 18 mb down while outputting 3.5 mb with a 1.2 mb buffer.
To be honest the i5 is not beefy enough for streaming and gaming on the same system.
