Binary string and integers in Visual Basic Express 2010
How do I make it so I can take a binary number up to 8 bits in a string "01010101" and then make it so they are in an array of Integers?
I will example by using letters.
String = "abcdefgh"
Binary(1) = a
Binary(2) = b
Binary(3) = c
Binary(4) = d
Binary(5) = e
Binary(6) = f
Binary(7) = g
Binary(8) = h
Please help, I couldn't find it on the internet and I need it for my Computing GCSE oursework
Use a for loop to loop through the integers in the string, here's a java example I sorta forget how to format vb.net so I'm not even going to try:
for (int i = 0; i = listOfDigits.length; i++){
    if (listOfDigits.getChar(i)) = "1" {
       NewList.set(i, "a")
      // repeat above block for 1 - 8
That's insanely rough and the syntax is all for Java but you get the idea, basically loop through all characters in the string, check if they're 1 - 8 then assign their letter to the new array list.
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
Module Module1
Sub Main()
Dim someString = "01010101"
Dim someArray(someString.Length - 1) As Integer
For i As Integer = 0 To someArray.Length - 1
someArray(i) = Convert.ToInt32(someString(i).ToString)
Next
For Each i As Integer In someArray
Console.WriteLine(i)
Next
Console.ReadKey()
End Sub
End Module
The single biggest problem in communication is the illusion that it has taken place.
I love how they are still teaching Visual Basic like it's got any current real world value!
C#, we can do it in one line!
using System;using System.Globalization;using System.Linq;namespace ConsoleApplication2{    static class Program    {        static void Main(string[] args)        {            const string SomeString = "01010101";            var someArray = SomeString.Select(c => Convert.ToInt32(c.ToString(CultureInfo.InvariantCulture))).ToArray();            Array.ForEach(someArray, Console.WriteLine);            Console.ReadKey();        }    }}
Alas, I digress :P
Module Module1    Sub Main()        Dim someString = "01010101"        Dim someArray(someString.Length - 1) As Integer        For i As Integer = 0 To someArray.Length - 1            someArray(i) = Convert.ToInt32(someString(i).ToString)        Next        For Each i As Integer In someArray            Console.WriteLine(i)        Next        Console.ReadKey()    End SubEnd Module
Does this work in the Windows Form Application or does it work in Console Application?
Alas, I digress :P
Oh well, VB is over soon, we starting Java and HTML in the new annual year (September) and hopefully C++ or C# in A Levels. But that's in just over 1 year away(I didn't realise how close it was before this sentence) :D
I just knocked it up as a console application. Lines #4 - #9 are what you're interested in really.
Very nice, those will defiantly serve you much better.
I just knocked it up as a console application. Lines #4 - #9 are what your interested in really.
Yea, this year's work was to get us into knowing computing and learning the basics, next year will be good! :D
Dim someArray = someString.Select(Function(x) Integer.Parse(x)).ToArray
or
Dim someArray = Array.ConvertAll(someString.ToArray, AddressOf Integer.Parse)
or like these
Private Function Str2IntArray(ByVal inStr As String) As Integer()
    Str2IntArray = inStr.Select(Function(x) Integer.Parse(x)).ToArray
End Function
    Str2IntArray = Array.ConvertAll(inStr.ToArray, AddressOf Integer.Parse)
End Function
first one is kinda like what was present above, but I like the second one as its more clear by reading what it does and slightly faster.
or
or like these
End Function
End Function
You're right, much faster and more concise.
